check "guages" flashing driving me nutz
ok i want this resolved once and for all. my check "guages" light keeps flashing intermittently at idle. it only does it at or near idle. this i believe is causing the car to hesitate at low rpms. when cruising or above idle its fine. what are the causes of a check guages light? i mean does it only go on for oil pressure, voltage, temparature, gas, etc?? or can ignition problems cause this? can you check codes for the check guages? could it be a bad alternator? please help.
Originally Posted by 11SECSS
If your voltage is going low enough during the idle surge then thats poss the problem look at your volt gauge while it doing it.
