No idea!
No idea!
I've been having trouble with search this morning, so hopefully someone will be nice enough to help me out with my list of ?s. I've decided that 400rwhp isn't going to cut it anymore. I've been looking at nitrous for a while, but a neighbor with a Cobra keeps telling me to look into forced induction, which I know nothing about. I'm leaning towards a supercharger since I already have LTs. Here's my mods:
Absolute Speed 2.5 5.3 Heads (flowed 314cfm @ .600 lift)
LG motorsports G5X3 114LSA cam
TSP double roller timing chain
ASP Underdrive Pulley
FLP LTs
SVT 30lb SVO Injectors
MTI Lid
So I want to know:
1.) Can I keep that head/cam set up with a supercharger? Is my cam too aggressive?
2.) Will I get less results from a certain amount of boost than a stock engine would, meaning, will I have to run more boost to obtain similar % increases in hp since I have higher flowing heads and an aggressive cam?
3.) Approximately how much boost would I have to run in order to get 600rwhp?
4.) Does more boost increase the risk of SC failure/damage or damage to the engine?
5.) Will I need to go with a forged bottom end at 600hp? How far can you push a stock bottom end?
6.) What's a good ballpark figure for the kit, fueling system and all the misc. parts for a complete system? (haven't called Bob @ EPP yet)
7.)What kind of hp do SC max out at?
Thanks for the info!
FLP LTs
MTI Lid
So I want to know:
What's up FL01ss? As being the former owner of this car I'm going to throw out my 2 cents. I would start working on reinforcing the drive line. The clutch, if you're still using the stock one, is at the limits as well as the rear end. I would address these issues and throw in a set of 4.10's along with the 9 inch or 12 bolt. Then I would get the car retuned a little more conservitive for nitrous. If I remember correctly it was tuned at 13:1 so you'll want to fatten it up a little to be safe. A good 125-150 shot should get you to or close to 600rwhp. If you got the forced induction way you'll have to tear the car all apart and spend alot more $$$.
FLP LTs
MTI Lid
So I want to know:
FLP LTs
MTI Lid
So I want to know:
BONUS~How's it going? I never got back to ya after my run in with the curb! I toasted the rack & pinion, but that was it. I'm lookin into a Moser 12 bolt, but I'm not sure about 4.10s. Might go with 3.73s. Lookin into a Spec 3 too.
BAD FNZ~ Thanks for the reply. If I would need to change heads, I'm just going to go with the juice instead!
