Who has Dart 205's/LG5X-3 and has dynoed?
Old 04-27-2006, 09:40 AM
VTTRAPNTA's Avatar
Default Who has Dart 205's/LG5X-3 and has dynoed?
I'm thinking about getting some dart 205's. What have you made with the Dart 205 and the LG5X-3 cam? Also, did you do 59cc and if so did you have to fly cut? I want to raise my compression without having to flycut if possible.
Is fly cutting really that bad for the piston integrity?
Old 04-27-2006, 09:30 PM
waterbug1999's Avatar
I have the Stage II Darts from TSP, G5X3 cam, 90/90. Im waiting on a few parts and should be ordering them tomorrow. Mine are around ~62cc (from what I know) and I will be running the .040" gasket as well. From the chart I use, http://www.rbracing-rsr.com/compstaticcalc.html , That puts me about 11.3.1 CR, which is cool with me. I am hoping NOT to have to flycut, but if I have to, then I will.
Should be starting the tear down and install NEXT weekend. So, as soon as I get that done and a tune, ill be sure to post up.
Old 04-28-2006, 12:59 AM
Houston999's Avatar
please tell us the results since i have a similar set up in my mind
Old 04-30-2006, 10:08 AM
Galen's Avatar
I just put mine together with the Stage 2 Darts and the G5x3. I don't have a dyno, but I can tell you it is running like a raped ape! I did flycut the pistons as a precaution.
Galen
Old 04-30-2006, 03:49 PM
VTTRAPNTA's Avatar
What is the cc on the heads? Did you get the stage 2 darts from texas speed?
Old 05-01-2006, 08:00 PM
Galen
How did you do it? Did you rent the flycuttin tool from LGM?
Are you going to dyno it at all?
Im going this friday to get a baseline.. I should start tearing the car apart this friday after I get back. Hopefully, it will go smooth and have her up and runnin in a few weeks.
