TR6 gap? on a 100 shot
Old 04-27-2006, 06:17 PM
00silver6's Avatar
Default TR6 gap? on a 100 shot
NX wet kit and i gapped the plugs @.030 is that to much cause im gonna spray a 150 shot after that and whats the grey normally closed wire on my msd window switch?
Old 04-27-2006, 06:21 PM
setxws6's Avatar
I ran a TNT 150 shot and left the stock gap in the TR6 plugs. I don't think you use the gray wire.
Old 04-27-2006, 07:16 PM
Restricted User
CAT3's Avatar
Gap of .30 is huge...I am sure you meant .030", which is pretty tight. I run mine b/w .035"- .038" for 150, .040" under 150.
Old 04-27-2006, 08:59 PM
Zinc's Avatar
Im right around .036 on my 100 shot.
Old 04-27-2006, 09:00 PM
daryl2cb@yahoo.com's Avatar
.038 of 150, you should be in the area noted above
Old 04-27-2006, 09:14 PM
Restricted User
CAT3's Avatar
00silver6, not to insult your intelligence, but do you know how to read plugs? If so, its always a good idea to check the #7 (most problematic cylinder) plug after a run. The plug will tell you a lot, timing, fueling etc.. GL
Charlie
