tranny cooler?
Old 04-27-2006, 11:59 PM
staringback05's Avatar
Default tranny cooler ?
how hard are they to install? what all is involved?
Old 04-28-2006, 08:42 AM
jmm98LS1's Avatar
They're very simple to install. Go to the automatic transmission section on this forum and search for cooler install. There's several how-to's with two different mounting options.
Old 04-28-2006, 09:19 AM
pSSycotic's Avatar
super easy just bolted mine to the radiator cut the hoses clamped them up with the new ones and clamped then tucked everything..even in the houston heat tranny never runs above 160ish
Old 04-28-2006, 11:36 AM
FBDYLVR's Avatar
One of the easier things I did on my car. I got the B&M 24K trans cooler and it came with all the fittings and straps I needed. Unless you have an aftermarket ram air setup (like FTRA), you should have no problem doing the install on the front of your A/C condenser and run the lines along the passenger side.
Old 04-28-2006, 01:05 PM
nice...thanks fellas
