MSD 6AL Questions
Old 04-28-2006, 01:35 PM
ToxicTA's Avatar
Default MSD 6AL Questions
Looking for information on how the MSD 6AL is connected to an Facotry Optispark. What may be needed, any links to information that may actually explain somebody elses experience.
Old 04-28-2006, 03:14 PM
musclehead's Avatar
The msd box does not directly hook up to the opti. It connects to the coil (which connects to the opti). I highly recommend you use a msd wiring harness for ease of installation (makes things a breeze). Next all you need to do is give it power via the battery, then ground it. You are done.
Old 04-28-2006, 04:25 PM
95zpro's Avatar
Yeah use MSD#8876 wiring harness and you will probably spend more time figuring out where to put the box than the actual time it takes to hook it up.
Old 04-29-2006, 01:20 AM
OutlawZ's Avatar
yup same here. gotta have that harness...... 4 wires off the harness to the box. box to power and ground.... two wires to the coil.... done....
Old 04-29-2006, 01:22 AM
ToxicTA's Avatar
Thanks for all the reponses I ordered the harness tonight.
