Master Slave question
drill mod, clutch swap and this MF'er master slave wont go back in
does that U bolt provide support on the master slave? Or can i just use 2 straight bolts? b/c this bitch wont line up!!!
unless someone has a trick?
I think you have to use the u-bolt. Yes, it's a bitch! I had to have someone on the inside with a flashlight to tell me where to move it to line it up and to pull the u-bolt through once it did line up.
does anyone know where i can get a u bolt so i can line up mine i think thats why mine started to leak cause it didnt line up right or if you know the part number for it, were exactly does it line up
When I did this I had a friend help me by looking with a light on the inside of the car. He would tell me which way to go. I do believe I had to sqeeze the u bolt together. It also helps to get one side started in the hole first but only started a little bit.
