Alright LT1 Guys - Lets hear opinions on this year's setup
Old 04-30-2006, 04:29 PM
stanger96's Avatar
Default Alright LT1 Guys - Lets hear opinions on this year's setup
this is my set up.....
-LT1... .040 over on TRW Pistons, stock rods & crank. Motor is fresh.
-The heads are professionally ported 2.02 I and 1.60 E...
-I'm running a custom grind Comp Cam (236/230 I believe, with 109 LSA. I'll grab the card later this evening to verify).
-This is on a Holley Pro-Form 750 Carb & GM Intake.
-Built TH350 trans and a Strange 12 Bolt with a suspension.
With all of this in mind, what would be the ideal converter I could get for my setup? That is a pretty hefty cam - so would it be safe to say that a Yank 4000 would be a good stall? This is the last thing to my puzzle.
I'll be ordering later this week once it is decided what is best. Streetability is not a priority - I have other cars to for daily driver detail.
*I'm hoping for low 12's on motor, then holding on tight with a 200 shot from the single stage plate kit. Does this sound feasable?
Any other info needed I'll provide - thanks ya'll!
Old 05-01-2006, 01:41 PM
stanger96's Avatar
ttt....anyone?
Old 05-01-2006, 02:37 PM
J2Pharren1's Avatar
I would call up fuddle.
Old 05-01-2006, 05:49 PM
blkchevyz's Avatar
why are you running a revers split cam?
Old 05-02-2006, 08:41 PM
streetwarrior96's Avatar
reverse split ??????
Old 05-02-2006, 08:58 PM
97blkz's Avatar
Remember that stall will flash higher on spray, my 3200 flashes at 3800 on spray, some thing to consider!
