Bellow size..
Old 05-01-2006, 08:14 AM
Z'mnypit's Avatar
Default Bellow size..
Im looking at a webstie that sells silcone hose's Im about to order one, but wanted to make sure I get the right size, I dont have my TB with me at work so could someone tell me if this is worng.
TB inlet side 4in
MAF inlet side 3.5in.
Or are they both 3.5in on both sides.
BTW this is a NW TB.
Thanks!
Old 05-01-2006, 03:38 PM
sickss228's Avatar
Do you have a 85mm MAF? If so just get the SLP smooth bellow thats what I did and it fit w/ no problems, I do have the 85mm TSP lid though. Also the fernco bellows arent as flexible or angled like the SLP and could cause you to crack the MAF or lid because of the angle it must bend at on a F-body.
Old 05-01-2006, 03:39 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I did a 4" on both ends, but I don't run a MAF.
Old 05-01-2006, 03:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I did 4" and 3" fernco from home depot. worked fine.
Old 05-01-2006, 06:28 PM
SSU's Drunk Typing Whore
Lithium's Avatar
4" was way to big for my nw tb and slp maf.
3"x3" fit after a pretty intense wrestleing match.
Last edited by Lithium; 05-01-2006 at 06:31 PM. Reason: Did not get home till 5 in the morning...so brain is not working.
Old 05-01-2006, 06:29 PM
bmfcamaro's Avatar
4 x 3.5 for 85mm maf and tpis tb.
Old 05-01-2006, 06:30 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I held your hand through that match!
Old 05-01-2006, 06:32 PM
Lithium's Avatar
I appreciate that. I know that I could not of done it without you, thats for sure. I still cant believe that I got that bitch on there.
Old 05-01-2006, 07:43 PM
Z'mnypit's Avatar
Cool looks like Ill be getting 3.5/3in. I dotn run a MAF so thats not an issue. I would order the SLP one but Ive found a website that sells them about less then half than what SLP wants for them. Plus Ive already had one of those . Id keep the stock one on there, but I ditched the power ring, ordered a new lid & Im not cutting this one so Im going to put the nozzles in the bellow instead of the power ring.
Old 05-01-2006, 07:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Home depot/lowes = $6.00
Don't sell yourself short Vann!
Old 05-01-2006, 07:59 PM
Lithium's Avatar
I am not even sure they make a 3.5" bellow (fernco)?
All I was able to find was 3"
Old 05-01-2006, 08:54 PM
Z'mnypit's Avatar
Nah, Ive been through the $6 ones also.. Ill PM yall the link to the site once I get to work tommorow...
Old 05-03-2006, 02:02 AM
konryod215's Avatar
fernco does not make a 3.5
Old 05-03-2006, 02:38 AM
Shallow Bay's Avatar
Anybody ever try Lowe's flexible version of the fernco?
Old 05-03-2006, 07:59 AM
Z'mnypit's Avatar
Its not a fernaco, its a slicone hump hose is what I bought.
