need some advice
Old 05-02-2006, 12:07 AM
1sickta's Avatar
Default need some advice
i'm sick and tired, everytime go over a bump, tunnel brace always scratch it specialist there is couple ppls in the car. and it will hits my y-pipe. how do i avoid this ? i still have stock shocks and springs.
thank you
Old 05-02-2006, 12:15 AM
9silverbird8's Avatar
whats your mileage? maybe its time for spring/shock upgrades
Old 05-02-2006, 12:16 AM
1sickta's Avatar
80K miles
Old 05-02-2006, 12:36 AM
Carter Hays's Avatar
Yea, probably time for some new parts.. Jack it up and have a look.
And I'm not trying to be a smartass but are you folks "overweight" by any chance?
Old 05-02-2006, 01:05 AM
1sickta's Avatar
no, we just 4 small asians inside 1 big american muscle car
btw do i need to change both springs and shocks or just shocks only ?
Old 05-02-2006, 01:26 AM
First, check everything under the car. Maybe something is loose..etc. Always replace shocks in pairs, and I've replaced single broken coil springs before, but only at the customers request, so I personally replace springs in pairs as well. (only OEM with OEM)
No, you don't have to do springs and shocks at the same time. If there is nothing abnormal/broken with the suspension, try a set of good shocks.
These cars have an extremely simple suspension design. Take a good look before you buy anything.
Old 05-02-2006, 05:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Sounds like you might be a good candidate for some poly mounts on either or the transmission and the motor mounts.
