Got another question for you guys..
With my new set-up, I bought, the PRC ls6 cnc ported heads, with the prc double springs tit ret's, pushrods, u/d pulley, 233/239 (233/239, .595"/.603") cam. Recent info was brought to my attention where a guy did a cam swap and his lifters would not keep up with his cam and robbed him a good amount of power, Should I be worried and buying lifters or would i be fine. And if so which ones should i look at or are good.
Thanks,
Mark
Thanks,
Mark
Replace with either stockers (new) or Comp 850-16
Everything else you're putting in is new, heads/valves/springs/p-rods/cam so why go cheap and leave a weak link.
You might be kicking yourself later.
Also change the plastic lifter cups, they are cheap.
Ok tho 850-16 are pretty cheap at around $210, where can i find plastic lifter cups. would i see any pwr gain with newer lifter? and while im at it should I replace the rockers? with a lighter stronger rocker kit.
