P1SC @5psi numbers
P1SC @5psi numbers
Dyno'd a customers car yesterdy(2000 Camaro). Stage 1 241's from TSP, 212/218 558/563 115. 92oct. Stock twin intercooled procharger kit, little belt slip. 60e vigilanti converter. It has SLP long tubes, catted y pipe, and unknown catback. Car is pretty much stock in other words. I ended up with 18 degrees of timing and still never seen one touch of KR 11.9:1 AFR on the dyno and 11.5:1 on the street.
It put down 463@6450 and 408lb/ft@5000. This is corrected, uncorrected hp was 487 for those who like the glorified numbers. This was at 5psi. No tricks on the dyno A/C belt still on, full exhaust, elbow and filter still on the procharger.
