AC Idle Pulley HELP!
I do beleive its just bolted on with a 15mm headed bolt. Its not to hard to change. Leave the main belt on. Just slide the ac belt off the idler pullies and remove the tensioner. Reverse to replace. I think it gets torqued back at 37 ftlbs.
Ya, after you said torx bit, I remembered thats what it was. On mine you could see where the bearing was getting hot around the outer edge. It made more of a humming sound more than a squeeling noise.
Yea this belt seems fairly new it still has the green strip on it relatively unfaded. I thought I fixe the squeaking but its happening in more than one place. Replacing the idler pulley quieted it down at idle but past about 1500 RPMs it squeals. I'm thinkin it might be the tensioner because it seems like it lets the belt a little loose when the RPMs climb... does that make sense?
