Switching to m6 questions?
Old 05-04-2006, 07:36 PM
I8RICE's Avatar
Default Switching to m6 questions?
I'm going to drop a m6 in my TA. I'm getting all the parts off a 2000 SS w/ 35,000 mi. What would you recommend I upgrade? I heard people change out the master cylinder. Which one should I go with? Also, what clutch do you recommend? The car is driven about 100 miles a month(Cruising). Never have time between school and work. I wont be going to the track probably till next summer(07) I'm still on a stock 10 bolt w/ 3.23's. I was thinking a SPEC stage 3 with the stock flywheel. My car is a heads+cam car w/ full boltons. I plan on spraying next year after i get a 9inch or dana 60. I'm looking for a clutch that i can cruise around in once in a while but will hold about 500 to 600 rwhp(N20) in the future as i will only put about 400 miles on it over summer. Any advice would be greatly helpful. Thanks.
~Rob
Old 05-22-2006, 08:02 PM
BigJoeBob1's Avatar
Get new everything you can, you wont regret it. Definitely new input and output seals. Also, upgrade the slave if it hasnt been already.
