Intake problem
Intake problem
I was trying to figure out a way to remove the resonator from the intake pipe and seal it up. I decided to just order the vortech 90 degree pipe. I had enough trouble threadding the air temp tensor(broke a couple of them). Anyway it's having trouble starting now, I have to hold the throttle open. I never drilled the hole for the vaccum tube either. Could that be it? Also I didn't thread the air temp sensor all the way because it started to crack. It might not be in far enough.
Originally Posted by RedRocketLT1
btw how important is little blue vaccum hose? what does it do?
