Too much timing?
Too much timing?
The shop that tuned my car contacted me today and informed me that my timing on my n/a tune was set at 31 degrees. Which kinda of scared me? I have a completely forced 346 w/ Diamond Pistons / Eagle Rods. The kit im using is a NX Dual Nozzle wet kit setup for about a 125 shot. I have sprayed it maybe 2/3 times so far with about 950 psi in the bottle. I have seen no knock on my diablosport programmer? Is it safe to spray what I am at the moment with the timing so high? Or should I go get a tune to lower my timing and maybe lose a few n/a horses?
Restricted User
Yeah. I shot 33* 120shot a lot, but found out that it does damage. Ended up having to replace the plugs after every w/e of racing, about 12-20 runs. Not to cool. If it tears plugs up it is tearing other **** up too. Confused though, your using the diablo ontop of custom tuning? With the diablo you can take out WOT Spark, or have the tune redone. Depending on the tuner though.
When I tune for wet, I keep the Spark around 28* from 0-.76g/cyl of airflow, then after that I reduce 2-3* per step of increasing airflow, for smaller shots, and more for larger shots. There really isnt a good reason to run 31* of spark though. I have done lots of testing with timing at the track and there is so little difference it can attributed to weather. So why push the spark that far and risk running it on the edge? GL
Charlie
Charlie
Charlie
Charlie
I tuned my car but did not even touch the timing tables so they are stock and I dont have any issues on the juice, but then again the leanest I am is mid 12's, all the way down to low 11's.
Charlie
Charlie
