ls6 intake added, both maf lb/min and map go down!!
Old 05-05-2006, 08:17 PM
TT_Vert's Avatar
Default ls6 intake added, both maf lb/min and map go down!!
I went from 42 lbs/min and 99 kpa at wot w/ls1 intake to 38.5 lb/min and 95 kpa w/ the ls6 intake. I figured the ls6 intake would take in MORE air. Am I thinking about this wrong?
Thanks
Dave
Old 05-05-2006, 09:07 PM
chrisj6's Avatar
wouldnt that be less pressure though in the manifold? Check out G/cyl, are you getting more there?
Chris
Old 05-05-2006, 09:17 PM
wait4me's Avatar
The throttle body or airbox now is your restriction then.. Pull the airbox and try again. If it went back to 100 then you know the cause. It went lower because you are using more air, but somthing in front of that couldnt handle the flow.
Old 05-05-2006, 09:47 PM
TT_Vert's Avatar
i have a c5 w/a vararam.
Dave
Old 05-05-2006, 09:49 PM
TT_Vert's Avatar
and g / cyl is down about .02
Dave
