TPIS no longer requires cores on 90mm T.B.
Tenured Member
We have finally finished making our own spring packs and levers for the cable operated 90mm throttle bodies so we will no longer need the cores to be sent in. You will just swap your throttle position sensor and idle air control motor onto the new throttle body and you are done. The fly by wire units will be shipped without the electric motor and gear assemblies, but the throttle position sensor will be installed and adjusted. You will just swap your existing motor and gears onto the new unit. Pricing will remain the same.
TPIS
TPIS
