Help! Autometer Hook Up!
Ok I have a 5" tach. I need to know where you guys hooked up the power and where you hooked up the ground. I have a LT1, which wire to I tap in for the RPM's.
I need to know a 12v power source that isn't on 24/7, just something that comes on with the ignition or light switch!
NEED RECOMMENDATIONS QUICKLY THANKS
!Josh
ANY PICTURES OR WRITE UPS WOULD BE GREAT! MAYBE EVEN A SCAN OF THE DIRECTIONS TO HOOK UP! I bought it used!
!Josh
You've got an LT1, so your wiring may be different than our PCM wiring.
Here's instructions from a guy with a 97.
http://www.fbody.com/tech/details.cgi?id=19
