Ram air box
Old 05-12-2006, 03:43 AM
aovall1's Avatar
Default Ram air box
Is it better to have a high, bigger gapped air flow for a 00 t/a or a much lowered, smaller gapped air flow? What I mean is it better to have the stock air box, or the air box that comes in the ws6 package?
Old 05-12-2006, 05:02 PM
TAQuickness's Avatar
Not sure, but I have stock lower WS6 box for sale if you're interested.
Old 05-12-2006, 05:05 PM
Cld069's Avatar
My guess would be the WS6 air box becuase air is forced into the intake manifold instead of being sucked in like a normal air box does. Just my opinion...
Old 05-12-2006, 08:48 PM
aovall1's Avatar
so the "ram air" box is better, and if so by how much?
Old 05-12-2006, 09:30 PM
tjswanson2001's Avatar
you'd be better off spending the money on an underdrive pulley instead of the "ram air" box. I would think that if you put your car on a dyno and compared the two boxes that you wouldn't see much if any difference. The ram air hood is mostly for looks anyway.
Old 05-12-2006, 11:42 PM
aovall1's Avatar
thanks, but if I do buy an underdrive pulley what else would I have to buy with it to install it? what changes will I see when I do buy an underdrive pulley? Overall, would it be worth the money?
Old 05-13-2006, 12:14 AM
SSU's Drunk Typing Whore
Lithium's Avatar
engine will rev quicker...should see around 10hp.
You will need some new belts as well.
Old 05-13-2006, 12:51 AM
Cld069's Avatar
I was talking to another guy tonight about ram air hoods, and he was saying to get the best out of your intake go with a cold air kit by TSP. I looked into it and it would be alot cheaper than buying a hood(unless you already have it), paint, and the box. Pretty much the same gain for $100s less. You could buy more mods with the money saved and end up getting more bang for your buck.
Old 05-13-2006, 12:54 AM
aovall1's Avatar
I bought the hood for looks and performance, got a slp ram air hood for 390? (i think its a good deal?) would you recommmend me buying a asp underdrive pulley? Does it have any downfalls?
Old 05-13-2006, 02:58 AM
aovall1's Avatar
is a 100 bucks a good deal for a ram air box and k&N filter?
Old 05-13-2006, 11:52 AM
Cld069's Avatar
First I need to make a correction on my previous post, the cold air kit I was referring to was not from TSP but Fasttoys. Compared to other ram air hoods I have found, it sounds like you got a good deal on the hood. Same on the air box and filter. I think the cheapest I have found for the box and filter is $295. All I know about the pulley is that it will help you rev quicker, but I havn't looked into them much.
Old 05-13-2006, 04:36 PM
that slp ram air hood is designed to work with your air box not the WS6 ram air box, so I'd just keep what you have and spend the $$ on other things.
Old 05-13-2006, 09:36 PM
aovall1's Avatar
thanks guys
Old 05-13-2006, 11:12 PM
Dip Stick's Avatar
Shrugs.. I have the slp ho ram air hood. SSRA and volant cai. I imagine without the baffles it might be a functional ram air hood... I just did the !FRA on the volant So t looks like it is using the ram air hood but mostly still relying ont he ssra.
Knew when I was shopping for hoods it wouldbe for looks anyhow
All the mods are just for show hehe
Old 05-14-2006, 02:28 PM
aovall1's Avatar
hey guys would you recommend me buying a asp underdrive pulley? does it have any downfalls? let me know what you think
Old 05-14-2006, 02:34 PM
Cld069's Avatar
The only downfall I can think of is if you have a big stereo, then you will have some charging issues with your alternator. If not, then yea it would be a good buy. It can also help extend the life of belt driven accesories. Hopefully that should answer some questions.
Old 05-14-2006, 02:44 PM
Redneck Z's Avatar
Personally I think the SLP/powerbond pulley is the best:
FEATURES:
Extra-tall belt-retention "walls"--no more thrown belts!
No aftermarket tensioner required
100% steel construction
Lighter than the stock balancer
Integral timing marks and puller-mounting threads
Keyed for high-rpm or supercharged applications
Does not cause false knock retard or erratic power-curve dips
Includes a new balancer bolt
Old 05-14-2006, 03:29 PM
Dip Stick's Avatar
shrugs, get the alt OD pulley with it..
Old 05-14-2006, 09:37 PM
aovall1's Avatar
I dont have any big system in my 00 t/a and dont plan on getting anything either, the monsoon is just fine, would it be ok to just buy the underdrive pulley by itself, and buy new belts, or should I get the OD pulley too like dentalguy is saying?
Old 05-15-2006, 07:38 AM
Dip Stick's Avatar
If you dont plan on getting anything extra to drain the alt/battery.. then the crank will be fine.. MAYBE summer nights,.. with lights on, radio on, and ac on max at a stop light idling.. you might get a slight dimming of the lights.. but prolly not.
