90mm TB CFM ?
Old 05-12-2006, 03:54 PM
Randy WS6's Avatar
Default 90mm TB CFM ?
how miny CFM does a 90mm TB flow compared to a Holley carb.
Old 05-12-2006, 04:02 PM
That's what she said...
TheBlurLS1's Avatar
It flows a LOT.
This thread claims a shop flowed it to 1200 cfm.
https://ls1tech.com/forums/generation-iii-external-engine/493553-nw-90-mm-tb-question.html
Another method: Pipe flow can be determined by (cross sectional area x 115) = CFM. The 90mm NW I have sitting here is right at 3.5" ID in the smallest part.
PiR^2 x 115 = 3.1415[(3.5/2)^2] x 115 = 1106cfm. You'll have to subtract a bit for the blade/shaft. Compare that to however big of holley you are wondering about. Not sure how accurate this is, but you get the picture.
You'd need one helluva holley to flow the same.
Quick Reply: 90mm TB CFM ?
