what is the most power you guys with prochargers & turbos are making on 02+ LS6 cams?
Old 05-12-2006, 04:31 PM
Chicago Crew UnderBoss's Avatar
Default what is the most power you guys with prochargers & turbos are making on 02+ LS6 cams?
Have plans to start having a forged LS6 block being built with an eye towards the future on my 02 Z06 making 600rwhp, with my 100% stock LS6 motor right now in my 02 Z06, powered by a D1SC East Coast Supercharging Procharger Kit, making around 10lbs of boost.
I have always heard what a great cam the 02 LS6 cam was for boosted f/i applications but figured i would put in a new larger blower cam in my new shortblock, but some of you guys have me rethinking this and now strongly considering just using my stock LS6 cam in my new motor (and save $ needed to upgrade to a 8 rib set-up instead of my current 6 rib) etc.
What is the most power you guys are making to the wheels with your LS6 cams and let me know what your power adder is and how much boost you running, along with compression ratio and what heads.
Thanks a lot this place ROCKS!!!!!!!!
Old 05-13-2006, 07:52 AM
Where are all you guys making huge power with an LS6 cam? I do know that KP has one FAST freakin f-body running mid 9s at 140+mph, with a 01 Z06 cam with a procharged D1SC as his power adder. That is VERY IMPRESSIVE and hauling the mail for sure on a stock cubed forged LS6 shortblock (with stock Z06 cam)!!
Old 05-13-2006, 11:08 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Maybe Mightymouse is running a Z06 cam.
Old 05-14-2006, 08:44 AM
To The Top, all you f/i induction guys with Z06 cams must be at the track this weekend!!
Old 05-14-2006, 10:25 AM
Zombie's Avatar
made 505 rwhp through my th400 at 10psi. Z06 cam is great drivability wise.
Old 05-14-2006, 01:58 PM
kbracing96's Avatar
TURBO8 just made 622hp and 684tq at 20psi with a 5.3 and a 02 Z06 cam and a stock botom end.
http://www.performancetrucks.net/for...7&page=1&pp=30
I'm running 1 also in my 4.8, but I'm only running about 6-7 lbs of boost, and making about 400rwhp.
Old 05-14-2006, 02:09 PM
CHRISPY's Avatar
I think MM was around 800RWHP with the LS6 but I might be mistaken on that.
Quick Reply: what is the most power you guys with prochargers & turbos are making on 02+ LS6 cams?
