Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
New Era Performance now has a brand new Dynojet chassis dyno !!!
Old 05-14-2006, 08:08 PM
Mike @ New Era's Avatar
Default New Era Performance now has a brand new Dynojet chassis dyno !!!
Just thought I would let everyone know that we now have a brand new dynojet dyno 224x rated at 1500 rwhp and 200 mph . We have been using an older land and sea dyno up to this point but the new set up is much nicer , has the ability to do more things and is very accurate . We also not only have hptuners software for just all ls1 appplications , but we now have it for all the ls2 applications as well .
Early summer dyno rates are : $275 will get you a dyno tune session for all N/A applications . Boosted and Nitrous applications will have to call to determine rates pending their set up .
Renting out the dyno including air/fuel readings : $100 first 3 pulls , $20 per pull after that .
These prices will be going up before the end of summer time .
Feel free to stop in the shop and check out the new set up , also for you guys that have been down before , we just added another 1100 sq. feet for our sales department and showroom .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Old 05-21-2006, 06:46 PM
redtail2426's Avatar
sick im going to be checking that out,i would like mine dynoed this summer.
Old 05-25-2006, 02:16 PM
Give us a call in advance when you are ready .
Mike
585-865-1832
Old 08-31-2006, 03:24 PM
mondi2002's Avatar
Default 2Bar
I just added a Procharger D1SC (8psi) with 1-7/8 stepped headers,
60lb injectors, & racetronix fuel pump. All stock internals, cam ex.
Running with 2bar now. Street tuned with HP tuners.
Would you recommend leaving it in 2bar or can/would you reconnect
the Maf. Approx how much would a Dyno tune be for my car
either way.
THANKS.
Old 09-01-2006, 11:55 AM
Matt@New Era's Avatar
We just tuned a procharged camaro this week @ 8 psi with a maf tune and it was fine . The maf tune is a bit more consistant for your power level , if you go much higher with the boost then the speed density tune would be better . $275 to tune it here .
Mike
Old 09-01-2006, 01:46 PM
mondi2002's Avatar
Question
Thanks, I will call to make an appt after the holiday.
I still have the Maf on there but is disconnected.
Getting like 200 mile per tank.
So theirs no problem with you uninstalling the HP tuners 2 Bar firmware?
The guy who helped me tune it was only familiar with 2 Bar.
