58mm Mono-Blade flows 1300 CFM. ANY GOOD?
Old 05-15-2006, 07:55 AM
Smokey TA's Avatar
Default 58mm Mono-Blade flows 1300 CFM. ANY GOOD?
58mm Mono-Blade flows 1300 CFM I was woundering if any has one one there car and notice the differents. if u know about them let me know cause i need a new TB. thanks of the output.
Old 05-15-2006, 08:17 AM
LT1BRN's Avatar
I think it depends on what u already have on ur car really, I have 58mm BBK, it flows 1000CFM, but i ported the intake inlets to the size that they fit.
I cant sa anything about resaults yet, cranking her up soon.
Old 05-15-2006, 10:04 AM
the_merv's Avatar
I wouldn't run that unless you have a stroked engine with a Cam and Heads. That is alot of CFM's
Old 05-15-2006, 10:56 AM
MrBill97396's Avatar
You can run it with heads and a good cam,good in size injectors, ported intake, and a good tune. There is no harm in CFM as long as you have the right combination to get it in good and out good.
Old 05-15-2006, 10:59 AM
Moderator
BizZzatch350's Avatar
It looks nice
Old 05-15-2006, 11:20 AM
lt197formula's Avatar
Like what MrBill said if you have the right heads, cam, intake, ect yes then it will work well. I actually need to get one of those bad boys along with porting my intake to bad I have no money for doing so now.
Old 05-15-2006, 02:40 PM
aggiez28's Avatar
there a 58mm tb (2 58mm holes) and theres the monoblade TB.
you should enlarhe the holes in your intake for either one as they are smaller than 58mm.
withthe monoblade you should cut a large hole the size of the monoblade opening, withthe 58mm tb you just enlarge the bores to 58mm
brook
Old 05-16-2006, 01:27 AM
Hot94Z28's Avatar
That is pretty big I think you would need alot of motor for that remember bigger is not always better
Old 05-16-2006, 07:27 AM
Honda Hunter's Avatar
Where can they be bought and how much?
Old 05-16-2006, 07:41 AM
Smokey TA's Avatar
under the sponsers called thunder racing about $550 i think there expensive!
Old 05-16-2006, 08:28 AM
LT1BRN's Avatar
what do u have?
I might trade u, I have BBK 58 and every one is tellin me its to big, I think its to late not, I just ported the intake inlet to fit the 58mm.
Old 05-16-2006, 08:29 AM
I have a 58 aswell. Ive always had my eye on a monblade though.
Old 05-16-2006, 11:09 AM
aggiez28's Avatar
all of AS&M's throttle bodies are great quality, i have owned one from all the makers and AS&M is the best quality by far.
they arnt cheap though
brook
Old 05-16-2006, 09:18 PM
95wht6spd's Avatar
I'm looking for a BBK 1544 58mm TB if anyone wants to sell their's.
Anyone know if an earlier model (for 92-93 LT1) can be made to work easily on a 95?
Quick Reply: 58mm Mono-Blade flows 1300 CFM. ANY GOOD?
