Code 16 (low res opti code)
Old 05-16-2006, 05:19 PM
Honda Hunter's Avatar
Default Code 16 (low res opti code)
What causes a code 16 (A low resolution pulse was not detected by ECM within 720 high resolution timing pulses)? If the Opti is for sure good what else would cause it? Seems to only happen at WOT.
Old 05-16-2006, 05:25 PM
Moderator
BizZzatch350's Avatar
Is the connector on the harness still good, any corosion?
Old 05-16-2006, 05:37 PM
I'll check. I'm pretty sure it is though.
Old 05-16-2006, 10:46 PM
Greaseymec's Avatar
I got this code when my opti died!!?? Check the connector at the opti and on the right side of the intake. Shoot a little contact cleaner in them. Good luck!
Mec
Old 05-17-2006, 01:15 AM
I hope it doesnt die. It's a Dynaspark that didnt come cheap
Quick Reply: Code 16 (low res opti code)
