Rocker Arms Question - Please help!
Old 05-18-2006, 12:34 PM
ksummers03's Avatar
Default Rocker Arms Question - Please help!
I have SLP 1.85 Rocker Arms and I am getting ready to put in a new Cam. Do I need to go back to 1.70 Arms for a Cam swap? Or will everything be alright.
Old 05-18-2006, 12:54 PM
conan's Avatar
Cam spec's ???
Old 05-18-2006, 01:57 PM
ksummers03's Avatar
The Texas Speed TSP XS Series Camshaft:
233/239, .595"/.603" 112 Lobe Seperation
1900-6500 RPM Power Band
Old 05-18-2006, 01:59 PM
ksummers03's Avatar
Or The Texas Speed Torquer 2 232/234 .595/.598
112 Lobe Seperation
1800-6400 RPM Power Band
Or maybe you have a suggestion on which Cam from Texas Speed I should get.
Old 05-18-2006, 02:06 PM
GuitsBoy's Avatar
I would definately put the 1.7s back for that cam. If you really want to keep the 1.85's then youll need a custom ground cam - or atleast something much smaller.
Old 05-18-2006, 02:08 PM
ksummers03's Avatar
Will the stock arms hold or do I need to get aftermarket. And if aftermarket, what brand would you get?
Old 05-18-2006, 02:17 PM
GuitsBoy's Avatar
Stockers will hold up fine. Some spill their bearings, but its usually luck of the draw, not necessarily the cams fault. You could always get the harland sharp modded stockers which are a little stronger and wont spill the bearings.
