Gear ratio on diablo sport.
Well has anyone encountered this problem? or used the Diablo Sport to change the axle ratio in the ECM?
I got an Ls1 2000 trans-am with T56 and it evidently has a different rear than stock. I did the math on the speedometer and I believe I have a 3.73. I can effectively change the parameters on everything else but I seem to be going nowhere when I do this.
Any help would be great.
My car doesn't have TCS so can't answer. On page 20 of the manual it does say when changing tire/wheel size the stock PCM can only calculate up to a "certain" tire size (whatever that is?) before it will disable it. Get the speedo correct first then see what happens. If it was messing up before tuning could be something else like a loose wheel sensor or something.
The current revision of that Predator is 2.12 and it now corrects for tire size and gear ratio changes correctly. To upgrade this one you have to send it back to the factory.
HTH
HTH
I bought mine from RWTD via paypal and printed it out - call them maybe they can tell by the serial no. or something - won't hurt to try. Only works on one car at a time after tuning right? So it's gotta be yours. Still thinking about sending mine in for the update, don't want to run on the stock tune while waiting...going to check it out.
