Does timing have anything to do with Air fuel ratio?
Old 05-19-2006, 04:22 PM
blackbird345's Avatar
Default Does timing have anything to do with Air fuel ratio?
If a wideband O2 sensor is reading 11:1 if I advance the timing shouldn't that ratio go up as more fuel is being burn?
Old 05-19-2006, 04:35 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
No. Why is it called an oxygen sensor? Because it measures the amount of free oxygen in the exhaust. It does not measure fuel, CO2, HCs, etc...Just the oxygen. That is why if you have a misfire, the wideband will show an extremely lean mixture, since with no combustion there is a lot of free oxygen that just got released into the exhaust.
Andrew
Old 05-19-2006, 05:07 PM
white2001s10's Avatar
Yes, try it and see for yourself.
There will be a point of advance where this no longer works due to misfires, and or preignition.
Old 05-20-2006, 12:05 AM
So I was correct then. Thanks. The wideband O2 reads the amount of air vs unburned fuel correct?
Old 05-20-2006, 07:52 AM
No not exactly. Oxygen sensors create their voltage signal based on the difference in % oxygen inside the pipe vs the % oxygen outside the pipe.
It's comparing the outside atmosphere with what you have in your exhaust and only looks at the oxygen.
It has no idea how much unburned fuel is in the pipe, just the amount of unburned oxygen.
It is common to see your wideband read richer when you lower your spark advance, and leaner when you increase the advance... but like I said up to the point of misfires.
The type of exhaust you have also matters. Manifolds and long-tube headers look very different on your wideband when you get to the point of misfires.
Manifolds allow the unburned fuel and oxygen to burn up faster in the exhaust. Long tubes allow them to stay unburned longer.
Old 05-20-2006, 08:19 PM
Ok cool, thats what I needed to know.
Old 05-20-2006, 10:30 PM
soundengineer's Avatar
also..in general..if you advance timing your A/F will go leaner..if it doesnt go any leaner then you are most likely at the most spark that you need for that particular cell...
its a good way to tell on the street when your spark advance is far enough and stops making power...
Old 05-21-2006, 12:01 AM
Thats interesting, thanks for the info.
Old 05-21-2006, 01:06 AM
Sorry...but if you use that method, your are asking for problems! Just my humble opinion.
Andrew
Old 05-21-2006, 02:07 AM
cantdrv65's Avatar
Post
On my car I make the same power whether Im at 24 degrees or 28 degrees of WOT timing...
Old 05-21-2006, 09:27 AM
Red99C5's Avatar
Timing will not change the AF/R. Not enough to matter anyway. I have seen dyno test of this. You can change the timing 20 degrees and you might see a .1 change. Which is nothing.
Old 05-21-2006, 10:01 AM
SideStep's Avatar
20 degrees!
I have seen the exact opposite. When I dyno 5-6 degrees of timing has moved my AFR by half a point.... and yes I was the one on the dyno and yes I was the one making the changes, 80 pulls.
You get to a point (for me it was 28.5 degrees) where no more advance moves the AFR. I brought timing all the way up to 32 degrees and got no more power but my AFR did not move either...
Old 05-21-2006, 05:39 PM
Red99C5's Avatar
Originally Posted by SideStep
20 degrees!
I seen it on the same run. They programmed the timing to go up and down at different rpm steps. This way there is no variation in air density from one run to the next.
Old 05-21-2006, 06:49 PM
no change in air density...
just in A/F..big difference..
more complete burn....and when it doesnt burn any better...thats where you get the most and cant get any further....
you will see A/F differences with spark changes..
I've puhed it around on a loaded and locked dyno so that I could show somebody before the differences and show how I found max power on the street..without a dyno being necessary...
Old 05-21-2006, 07:13 PM
GuitsBoy's Avatar
I have seen my fuel trims change 5 to 7 easily by changing just a couple degrees of timing, especially at idle with a cam.
