Map sensor forgot what that is?
Old 05-19-2006, 11:54 PM
94 z28 A4's Avatar
Default Map sensor forgot what that is?
My ses light is on and the map sensor is out and i forgot what it is and what it is for. Thanks
Old 05-20-2006, 12:00 AM
buffman's Avatar
it's the black little box thing on the passenger side of the intake towards the TB. it has a green 3 wire connector. Two screws hold it in the manifold
Old 05-20-2006, 12:37 AM
OutlawZ's Avatar
It's your Manifold Absolute Pressure sensor... It measures pressure inside the intake usually in kPa and converts it for your PCM to use to measure air volume I believe for use in it's fueling algorithms.... More MAP voltage equals higher engine load.... 1 bar MAP sensors for NA engines and 2 bar or 3 bar for boosted motors since boost pressure goes higher than a standard 1 bar map sensor will read....
If it was out your motor wouldn't be able to accurately measure air volume and engine load and wouldn't do a great job in fueling accurately...
Old 05-20-2006, 12:58 AM
daniel6718's Avatar
i have a brand new one ill sell youfor 10 bux
daniel
Quick Reply: Map sensor forgot what that is?
