Do you have to change the oil after spraying AmsOil Power Foam into your engine?
Old 01-08-2003, 08:56 PM
Martingale00's Avatar
Default Do you have to change the oil after spraying AmsOil Power Foam into your engine?
I know that with the GM Top End Cleaner they change the oil afterwards because some of the cleaner can creep past the rings. I sprayed some of that AmsOil Power Foam into my throttle body to clean out the intake. It smoked like a son of a bitch out of the exhaust for a good 30 minutes afterwards. I didn't even think to change the oil. Is it necessary with this stuff? Thanks...
Old 01-09-2003, 01:22 AM
Default Re: Do you have to change the oil after spraying AmsOil Power Foam into your engine?
ttt
Old 01-10-2003, 05:43 PM
WILWAXU's Avatar
Let try again ttt
Old 01-10-2003, 06:16 PM
JayLS1-327's Avatar
I would change it just for peace of mind.
Old 01-11-2003, 04:24 PM
JF WS6's Avatar
Don't know for sure, but if it does the same thing as the GM top engine cleaner then yeah I'd go ahead and change it.
Can't hurt right? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Quick Reply: Do you have to change the oil after spraying AmsOil Power Foam into your engine?
