Strange thing happend... problem?
Had something happen, which it did before, just not anywhere as severe. Went for a spirited run, 2nd gear 2500 to 6500 WOT, everything fine. Came to a stop and then when I went to pull out, I had no real control over the clutch. It was either fully engaged or not. It was like slowly letting the clutch out and all of a sudden, it just grabbed like I dumped it. Push it back in, try again, and go to pull out easy, bam... same thing.
Drive for a little while and the problems gone.
Any info?
Any info?
What kind of clutch?
My cartek does that sometimes after it see's some heat from a track run.
I'm guessing between the burnout and the launch, the heat generated causes the pucks to really grab and not allow me to slip it.
