upgrading pcm and wiring harness
You need the pcm and the engine harness. The dash harness. The gauge cluster. The fuel sending unit. A 99+ temp sender.
You may need a chassis harness too, or repin some of the wires on the three fenderwell connectors -- for this part I'm not sure if it's the same or changed.
