Notices
lt1
Old 05-25-2006, 11:14 PM
daniel6718's Avatar
Default lt1
lt1 rear brake caliper bracekts...
non tcs wire harness from body to rear end...
95 wire harness
rear sway bar bushing...
abs sensor...
oil sending unit on back/top of block
motor mount triangle shaped
Old 05-27-2006, 12:42 AM
daniel6718's Avatar
nobody
Old 05-27-2006, 05:10 PM
Bad Seller Warning!
96 LT-1's Avatar
Default Abs
PM me about the ABS unit.... i took mine out ill sell you the whole LT-1 ABS unit.
Old 05-28-2006, 12:02 AM
daniel6718's Avatar
abs sensor on the top if the rear end...i dont need the abs unit
