Help with M6 Radial car please.
Car setup is as follows, 9inch, 4.11 gear, truetrac, BMR adj. torque arm with reloc crossmember, -2 pinion angle, UMI rod ended lca's, No relocation brackets, CE rear shocks set at 50/50, stock swaybar, as of now stock front suspension with the swaybar removed, 15x3.5 prostars w/ moroso ds-2s. Stock t56 with a textralia clutch and pro5.0 shifter, cam and bolt on car making roughly 390rwhp. 255 MT et radial on stock 16x8 rim @ 15.5-16.5 psi.
Anyways the problem came with the car hooking hard then bogging HARD. I would dial up 4500rpm's and on the last yellow I would swing the rpms and drop the clutch. The car would hook hard and lift the front wheels a few inches in the air and then bog down hard. I am curious what to try, more rpm, stiffer setting on the rear shocks? Would relocation brackets help? What about moving the IC further infront of the car? I am sure getting the junk shocks of the rear along with replacing the stock stuff up front would help, but I would assume the car can still leave somewhat decent with the setup it has now.
Any input would be greatly appreciated. Thanks in advance.
