2-3 takes for ever to shift on spray
I just had my tran built and im having the same issue that i had with the stock one, when im on the bottle the 2-3 shift takes for ever. is there somthing that could be in the tune causing this to happen all TQ managment has been taken out.
you need to play with the rpm/mph tables to get it where you want it. took me like 5 bottles to get the spray to shut off and immediately (guestimate .5 seconds) afterwards shift- and i just recently got it dead nuts before the trans went out . the issue was completly unrelated to the clutch packs also so the method i describe is pretty safe if you are careful.
the way i got it the best was lowering the rpm table for the shift points out of the picture and using mph to find the correct shift point. spray makes the converter stall higher/slip more so it can mess with the rpm settings, as i have a completly different bin. file for nitrous.
