crank re-learn
Old 05-27-2006, 11:30 AM
minytrker's Avatar
Default crank re-learn
How can I do a crank re-learn on a 99 f body with a 402 in it with a turbo 400 tranny. The car was a 6 speed car and now someone else flashed it with an auto pcm. The problem is it is missing half the stuff it needs to do the re-learn. There is no vss, no parking brake, no computer at all for a auto so when I try the relearn it just fails because of everything missing. Im using efi live if that helps.
Old 05-27-2006, 12:41 PM
Black02SS's Avatar
I believe you need to flash a M6 file for it to work.
