FMIC Installed (w/pics) Boost control Q too.
1 Post
Installed a FMIC yesterday. All I can say is that was a LOT of cutting things that probably should not be cut (bumper included) Anyhow, it DEFINETLY makes the intake temps cooler. I can touch the intake pipe going into the throttle body after driving the car now and not get burned. Thanks to Billy at TRT for sending the pics (and the kit). Made install much faster.
BTW.....of course now I'm not making full "boost" with the STS referencing the wastegate off the back of the turbine. How should I re-reference my boost to the wastegate? Run a line from the front of the car. Even better, I have an electronic boost controller (the STS one) and NO instructions. If someone can provide pics or at least clear instructions that would be a bonus.
Thanks.
Here are the pics:
Thanks.
Here are the pics:
1 Post
Originally Posted by RooRnZ28
looks sick... how's she run?
Thanks for the compliment too.
Restricted User
Phil, hit up the Military Forum, there is a guy wanting info on Flight Warrant I told him I'd direct you over there. Thanks.. I had an idea for your front plate, unless you already put it on, will go over that tomorrow if your around.
1 Post
