Those of you w/poly motor mounts inside.
I have FLP headers that slightly bangs the floor board and transmitt's false Knock. I Know this because I wedged a rubber hose between the Y pipe and the floor board for a test and scanned the car using EFIlive. I am thinking of perchasing a poly motor mount but want to know if there are any un forseen problems I might have. Will I have more vibration? Will I potentialy break something due to the motor not being dampend as much? Thanks in advance.
Re: Those of you w/poly motor mounts inside.
you will not break anything, and you will not see any added vibration. i put both driver and pass. side in and no added vibration at all. and no added kr either. i used to get a little kr every once in a while(at WOT) before i did the poly mounts anyways
<small>[ February 01, 2003, 09:50 AM: Message edited by: ROB'S SS ]</small>
