tuning boost w/ 1 bar ??
Ok first I already know a 2 bar would be better so dont reply with that.
How is everyone running boost w/ a 1 bar setup tuning it? w/ hptuners.
Are you using a 2 bar sensor w/ the 1 bar operating system or a 1 bar sensor still?
And if you use the 2 bar sensor does it split the VE table in half? like 1-50kpa would actually be 0-100 and anything over 50 be boost?
Whats the best method for starting to tune this way? would SD be better? and obviously tune the VE table w/o boost then what is a safe PE table to start with?
I have a WB setup but no EIO for HPtuners.
thanks.
thanks.
