# of bolts on 4l60 tranny
are there 6 bolts or 8 bolts connecting the tranny to the engine???? i got 6 off and the thing isnt comin off. if there is 2 more where are they? and how do i get them off?
gotta unbolt the converter also. Make sure you unbolt the x-member, and let the trans sag down to get at the top bell housing bolts. you will need ~36" of extensions. I use 2 24"'s. first time I had my trans down the dowel pins were seized up and it was a major PITA to get them to let go.
Hi,
I am missing the 2 lower bolts connecting the bellhousing to the oil pan.
One goes thru the bell housing into a threaded hole, the other looks to need a nut on the other side.
What size are these bolts so I can replace them? GM Part no.? What is the torque to tighten?
TIA
TIA
