TSP MS3 Cam and Head Question
I have the MS3 Cam Kit with the PRC Gold Springs (uninstalled) and I was looking at some heads from TSP, with the Competition CNC Valve Job:
TSP Heads
The specs on the MS3 Cam: 237/242 .603"/.609" 113 LSA
3 questions:
1. Will the MS3 Cam fit these heads without flycutting the pistons; is this a bolt-on with no modification required (02 Z06)?
2. Since I already have the cam kit with the PRC Gold Springs, hardened pushrods, retainers, keepers, etc... do I need to buy anything else (new valves, lifters) for these heads or will I just use the parts on the stock heads?
3. What kind of gains can I expect?
Thanks.
Chris
TSP Heads
3 questions:
Thanks.
Chris
Im sure somebody will answer this, but if you have real questions-concerns the best people to answer this is they guys at tsp, jon is a good guy and will gladly answer any questions you have. Oh while your in there might as well do new lifters and injectors. "Gains" since you have a 02 z06 id guess youd see somewhere between 75hp to 90hp increase prob more with proper tuning.
TSP Heads
3 questions:
YES, with stock valves, unmilled and stock gaskets.
Lifters would be a plus since the heads are off. Either stock or Comp 850-16
Properly tuned anywhere from 30>40+ rwhp
Thanks.
Chris
TSP Heads
3 questions:
Thanks.
Chris
so your saying with the tsp ls6 ported heads with comp valve job and the ms3 hes only goin to see 30-40 rwhp with a proper tune?? That sounds awefully low, maybe with the ms3 and a proper tune hed see that. id add another 30 hp or more with the heads.
Pianoman90. with MS3, heads, and tuned you should be over than +410 rwhp.
I think PREDATOR-Z has answer your questions very well.
30>40+ rwhp tuned (give or take a few)
Originally Posted by PREDATOR-Z
No, I'm saying that adding heads stage 1 to his cam only setup will see that much
Add that 30-40hp from the heads to the 40-50 from the cam and a good tune and your sitting at 70-90 more hp. I believe I read a post TSP made a while back about how they could bump up the compression on those heads some without sacrificing PV clearance with the MS3 cam. They also have a new smaller sized, higher lift cam (MS4??) matched with their PRC LS6 heads with higher compression that made 460/400+ in a 6.0L.
I would def. do some lifters and injectors while you are in there-get it all done and tuned once.
BTW it's nice seeing people actually MODIFY their Corvettes
I am doing the same exact heads/cam setup in my brand new TSP Forged 347ci engine that I am assembling right now. I won't have numbers any time soon but I expect around 450rwhp with everything I have below. Should be a nasty setup
I suggest new lifters, OEM or aftermarket. Your springs and harden pushrods are fine.
