15x10 Prostars with 325 Nitto's help!
So...I started putting them on today, went well until the tires started rubbing on the inside right below the bump stop, and by the fender *not the fender, but the inner fender right next to the control arm. I had to grind A LITTLE bit of the side of the control arm to make that not rub, but both sides are rubbing. It seems like the drivers side has more clearance than the passenger side. What can I do to solve this issue? Do I have to keep banging as hard as I can until the inner fender goes in more or what?
Do you guys recommend getting both a panhard rod and rear lower control arms, or one or the other? I'm getting adjustable, so is that something I would be able to install myself without a pro? Which panhard rod/rear control arms would you recommend?
I want to stay within a decent budget, nothing too expensive.
