Which Eagle rods for these JE pistons?
I just got these JE pistons-these are the specs: JE LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs 3.905" BORE / 3.622" Stroke / 6.125" Rods / 1.175" Comp Height / .927 x 2.500 (118g) Wrist Pins .
Now Eagle sells 2 6.125 rods:
CRS6125B3D 6.125 660g Uses .927" piston pin / w/offset
CRS6125O3D 6.125 620g Uses .927" piston pin / on center
One is one centre-the other has an offset? Which one do i need-I'm using the stcok crank? Also what is the difference besides the weight?
Thanks!
Thanks!
I can shift faster than you.
Both will work just fine, but the on-center rod would be the better choice as the LS1s have an on-center rod from the factory. I'm using them in my daily driver 382ci motor with the ARP2000 bolt upgrade. For the money, they are hard to beat.
Jason
Jason
Hey Jason-small world-these are the pistons you where selling a while back. Thanks for the info-i'll order up the on-center rods-and the bonus is there lighter too. Why is that? Also are the 2000 rod bolt upgrade worth it-this for FI bottom end.
