Installing New Cam, What Else Do I Need?
Swapping in a Tr224/224 112 along w/ CNC Ported stock 241 Heads.
Here is what I have on the to do list so far:
LS6 Oil Pump
LS2 Timing Chain
Comp Cams 26918 Valve Springs
Thunder Racing Pushrods 7.400
Heads Gaskets
Exhaust Gaskets
Water Pump Gasket
Now should I also replace:
Water Pump
Lifters
Other Misc. Gaskets?
What else?
The car has almost 90,000 on it. Thanks a lot. I just want to konw what is absolutely necessary and what I can re-use. Thanks!
LS6 Oil Pump
LS2 Timing Chain
Heads Gaskets
Exhaust Gaskets
Water Pump Gasket
Water Pump
Lifters
What else?
