GMR Speed Twin Turbo
They have not been selling it very long so it might be awhile before you see some numbers.All turbo kits with similar stuff put out similar numbers. Its not magic however remember to really put down numbers you need to be optimized..right rear end gears,drag tires..strong rear end..possible suspension stuff and things like a two step ,stalls in auto cars..clutch capable of holding the power in a manual car.tuning etc.
I would expect easy mid to low 11s out my twin kit with supporting mods and on my nittos. 10s should be doable.I am not trying to do eights or anything silly on the track Fact at 11.5 my cars track days will be over. No cage is going in my 99.
Not with current NHRA rules of back crossbar having to be permanent.
I believe I have the only gmr speed twin turbo that's in operation at the moment. I'll be putting some passes on her once I finish building my driveline. Just did the moser 9" & 3.5" Alum DS. Getting a TQA, lca's, and DR's then she should be ready. With some speedy shifting I don't see why I wouldn't touch the 9's cause I've done 200+lbs of weight reduction already.
