just bought new clutch, what else do i need?
like it says, i just bought a ram powergrip hd with the 910 disks and the billet flywheel, my stock clutch is pretty much fried. i am wondering what else is there that i can do/need to do to make the clutch/trans system better and stronger while the transmission is out of the car so i don't have to go back later and do it again. any help is greatly appreciated. thanks!!
JM
JM
If this is the car in your sig (2000 TA) then update your master and slave cylinders.
Change the pilot bearing, and a new throwout bearing (can sometimes come with a new slave cylinder).
USE RED LOCTITE on Flywheel bolts and pressure plate bolts. Torque them to specs from the manufacturer.
how many miles are on the car? a rebuild to make the trans stronger could be helpful while its out anyways. I have heard t56rebuilds.com does a rebuild in a week or so and is good for pretty high power output.
