PCM VSS pulues mod ?
Can either EFILive or HPturner the PCM to accept the VSS input singnal of a Viper T56 and it number of pulues ?...
Trying to swap a Viper T56 on to a LS1 in my Chevelle. I have modified the Hyd clutch slave to work. But will need to do something about the VSS. My other option is to take the backend off and machine a F-Body reluctor wheel to fix the Viper output shaft. (more $$$) Trying to find out if the VSS sensor will fit into the Viper tailshaft housing.
