85mm MAF + Stealth Air Box?
Does anybody out there have this combination of induction parts? If so, did you have any fitment issues? How do the two work together? Any info you guys can provide would be greatly appreciated.
TIA,
Brett
TIA,
Brett
Re: 85mm MAF + Stealth Air Box?
i have the stealth box but with a stock maf.my box fits well,almost oem(if i had stickers to put on it)the problem is the bellow they give you.due to the size of the box the lid neck shoots down at almost a 45 degree angle while the throttle body is level with the ground:
neck= \ tb= -
the bellows is almost like shrink tubing and constrics on it self(narrows alot in the middle)
ill be working on a new bellows pretty soon before i get my car out of storage.keep in touch ill let you know what i come up with.(or someone can chime in if they already addressed this)
as far as the maft....it should fit the hose that comes with it is pretty flexible.unless your up in to the 400's for hp the mass isnt going to give you enough to justify the price though. hope this helps. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
neck= \ tb= -
