high rpm closed throttle with SC
Old 06-04-2006, 07:05 PM
stevieturbo's Avatar
Default high rpm closed throttle with SC
When racing etc, what is better for belt longeivity and the blower in general on closing the throttle after a pass ?
Is it best to remain in the gear on closed throttle, and let rpm's fall with vehicle speed, or slip it into neutral, and let rpms fall to idle pretty quickly ?
Or does it not matter either way ?
Old 06-04-2006, 07:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
You just need a good bypass valve that opens quickly and let's out enough air.This will reduce the strain on the blower/belt combo.
Old 06-04-2006, 07:36 PM
I can hear the air venting no problems up high, but the fluttering noise comes back in around 3000rpm, in gear after shutdown.
During normal driving, on gear change I get the fluttering too. Not sure if this is a concern or not ?
I have a couple of Greddy 38mm ( 1.5" ) BOV's, with their springs set as soft as I can ( 2 springs normally fitted, I removed one )
One is before my IC, one after.
Old 06-04-2006, 07:42 PM
Z8'S's Avatar
You need to be able to vent more than what those Greedys' are capable of.I ran a pair of HKS super seqs.and had nothing but trouble with them.Stepped up to a pair of Vortech Mondos' and was MUCH better.I am now running the new Vortech Super Mondo which flows 1200+cfm.
