g5x3/ TSP prc ls6 heads people, need info???
did u guys mill ur heads? how much did u mill them 2? if they get milled its obvious that i have to flycut right? where do i get the flycuting tool from? thanx and any other info wood be good thanks!!
All i can answer is yes if you mill with stock pistons you will have to flycut.. LG Motorsports has the tool. I've heard it's a pain to get it from them though and is almost cheaper to just buy one yourself and easier since you don't have to wait on them...
Well, I do not have the heads you are speaking of, but I did notch my pistons. I think that if you mill your heads (& gasket thickness), it will limit to what size cam you will be able to run...
I had no problem renting the the cutting tool from LGM. Called them on a Monday and had the tool on my front door by Thursday. Notched them on a Sat. (2-3 hours) and sent it back on Monday.
